Just bought a boat with an older Ox66 and unknown service record. She seems to run nicely except for at WOT she exhibits the infamous "fall back" symptom where she'll run up to 5,100 or so then drop back to the low 4's (pegging the GPH gauge) until I back slightly off the throttle, then she'll run back up to the low 5's. If not run at WOT, you'd never know there was a problem. On a Parker 2320 EC, she's burning about 12 gph at 22 knots, and I think there may be a bit of upside to that fuel burn rate.
I want to go through all the regular maintenance parts to establish a good "baseline" but of course I can't do everything in one day. So the question is - "Where to start?"
I've got a wonderful box of new parts sitting here ($600 worth) and wondering if I'm on the right track. My plan is as follows:
Phase I: fuel system
Phase II: Cooling System
Phase III: General tune-up
So how are my priorities? Any advice, or is there anything I might be missing? What else goes into a "tune-up"? I have the factory manual on my computer, but have not read all the relevant sections yet...
Thanks in advance!
- Replace Sierra 21 micron filter with Racor 10 micron unit with clear bowl
- Replace engine mounted fuel filter & gasket
- Replace (3) low pressure fuel pumps
- Replace VST filter (damn those things are expensive for what they are!)
- Replace thermostats (2)
- Complete rebuild of water pump (including ALL new parts)
- Replace pressure relief valve ("poppet" valve)
- Clean O2 sensor and dip tube
- New Spark Plugs
- (Already replaced LU oil during pre-purchase inspection)
Thanks in advance!
