its hard to find impellor for my 1977 evinrude 35
abicassar
hi can someone help me please i have a 35hp 1977 evinrude model no 35753c fitted with water pump housing 323941 can you please guide me which imellor fits this motor since when we check the parts catalouge is giving an impellor that is different thathe one fitted in my motor
Thanks in advace
envader
Re: its hard to find impellor for my 1977 evinrude 35
Are You using the brp cataloge. The part # should be 0378891
tashasdaddy
i find impeller 378891 superceded #775521 ir sierra 18006 water pump kit, 388256 superceded# 389980.
got info from here http://shop.evinrude.com/ and ishopmarine.
abicassar
thanks for your reply but it seems that the part no on the catalouge OEM is different thanthe one fitted in the motor since i ve seen the new part and its totaly different my impellor is smaller .i would like to know what impellor i should use with housing part no 323941
thanks
steelespike
There appears to be 3 pretty distinct impellers.18-3006,
3051,
3083
It is supposed to be 18-3006.assuming you indeed have a 35hp leg
that leaves the 3051 and 3083.pretty distinctly different from one another.
If you check the impellers right here at Iboats I think you may be able to pick it out.If not perhaps an impeller for another model will ring a bell.
tashasdaddy
i got my info from the BRP Johnson/Evinrude parts diagram site, for your model numbered motor, then crossed referenced them at ishopmarine for the sierra part numbers, if you order the kit, it comes with everything.
i find impeller 378891 superceded #775521 or sierra 18006, water pump kit, 388256 superceded# 389980.
