Boomyal
- Aug 16, 2003
- 12,072
I just removed the trim/tilt pump solenoid from my 1976 BeachCraft Merc 888. I ran further tests on the bench to confirm that it would not pass current to the terminal that would send it on to the pump.
I then drilled the rivets out and removed the bottom plate from the solenoid. I'd never seen the inside of one of these before. They are pretty simple. The fact is that all the contact surfaces had minor gunk on them. None of the parts were burned or distorted. It was all age and inactivity related damage.
Now if only I had some good Dremel brushes, I could clean all those contacts and bolt the bottom plate back on. I'll have to go looking for a good set of brushes to do that with. In the mean time, I ordered a new solenoid. They were cheaper shipped than from the local NAPA and it was going to take the same amount of time to get it.
The moral of the story is take it apart and examine it before you buy a new one.
