It's a Rude but no numbers
jusfloatin
Good day to all
I picked up a 55 Durajet (Evinrude motor) from a Police auction.
I am sure that this motor had numbers at one point but they were removed by the previous ( I doubt I can say the previous owner ) holder of this motor.
It has been renumbered by the boys in blue but those numbers are for idenitity only.
The reason for this quest is I would like to add a starter but without a factory model/serial number number I am stuck.
What can I do?
Vic.S
Re: It's a Rude but no numbers
Original numbers not still on a core plug somewhere on the powerhead?
Post some pictures. General ones of the ouside from all angles and some of the powerhead to show all the vital parts. Someone may then be able to narrow it down close enough for obtaining parts etc
tashasdaddy
look for the welch plug on the block
jusfloatin
There is one on the top G3128068
kbait
Post a photo or 2. The great folks on here will zero in on it!
ezeke
Engine Serial number is probably 1993, possibly late 1992. The Durajet is custom and may have been converted later.
kbait
hey ezeke.. do you have a link perhaps to a serial number code for johnnyrudes?
ezeke
No. I use the iboats advanced search engine for similar serial numbers and try to fit the serial number to the range. For example, search G0312* and G312*.
A BRP dealer can get the actual information from BRP.
kbait
Thanks for the tip!
jusfloatin
Just waiting for the camera batteries to charge up and I will post some pictures.
I was thinking it was early 90's too but there is no better place to find the correct answer to any boat question is to post your question here.
bob johnson
look for another welch plug...
I think one has a serial number and another might have the model number.
sometimes they are hidden under stuff...but sometimes you get lucky
bob
jusfloatin
I have looked everwhere on that motor, other than the welch plug on the top the only other ones I could find was on the carbs but no numbers.
Heres some pictures.
kenmyfam
How about a photo of the cover ???
tashasdaddy
take serial number a good J/E shop, they will get you the year. serial numbers are not published.
or call BRP direct, Call 1-847-689-7090
jasper60103
Hey, you stole my motor! :D
TN-25
From what I see it looks like a commercial 55 horse. Those are the loop-charged twins that were offered in 50, 55 & 60 horsepower, The commercial motor is a detuned 60 horse with a pull start and a taller cowling to clear the pull started assembly.
