It ran without cooling for a minute-damage?
I was given a 1990 15 hp Gamefisher/Force motor that hadn't run in 10 years or so. After rebuilding the fuel pump and carb (which were full of sediment and corrosion), it started on the second pull. I shut it down immediately, then put thelower end in a deep bucket in water deep enough to cover the water intake. I fired it up again, and waited about a minute for water to come out of the water outlet. It did not, so I shut it down. What's the likelihood that the engine was damaged by lack of cooling?
Barnacle_Bill
Re: It ran without cooling for a minute-damage?
That short of time shouldn't hurt the motor but you do need to change the impeller.
Thanks, Bill. Yeah, the impeller's so old that the arms have taken a "set" to them so that they don't expand out to the wall of the pump on the wide side. Based on what I learned from the friendly peolple here, I expected to have to replace that. Also, there are some pits on the inside of the pump body, so I'll be replacing that, too. When I ran a stream of water up the water pipe (motor not running), some kind of plant matter became dislodged (or an insect nest - the motor was covered with mud dauber nests when I started this project), and a lot of water started flowing out the outlet, so at least I know that's clear now.
sailingwest
Hi gamefisher ,you can run the engine safely with hose attached to pick up pipe just keep it at tickover.
Thanks - it ran great today on the water (with a new impeller), so nothing catastrophic has happened.
