Re: Issues with using Aluminum heads on Iron Engines
Here.
Look at these.
The official specs for a GM marine 5.7L
So at 2500 RPMS, a BONE STOCK GM MARINE ENGINE is making 360 ft/lbs of torque (FROM GM MARINE'S WEBSITE)
AFR's DYNO website
This is a custom built 350 using the pretty much the most expensive and best regarded aftermarket aluminum heads for the CSB.
And at 2500 rpms, the engine is making *drum roll please* 360 ft/lbs of torque.
SO. Using links to GMmarine, and AFR, I have proven that aftermarket heads do NOT give you more bottom end torque.
In fact, if you look at the angle of the dyno graphs, at 1500 RPMS, the bone stock gm marine 5.7L would be making MORE torque.
torque @ 1500 RPMS is basically you're hole shot.
I would argue that at 1500 RPMS, the AFR heads are marking 20% less torque than a BONE STOCK GM MARINE 5.7.
Why do you think GM posts their dyno graph almost down to idle, and AFR STARTS their dyno graph @ 2500 RPMS?
Really...
I could have swore it was because they made millions of them and they had work on numerous applications.
Again, LOOK AT THE DYNO GRAPHS, a chev pickup truck will spend 95% of it's life bellow 2500 rpms.
The STOCK heads are clearly better bellow 2500 rpms. If they ported and polished their heads, or if they ran aftermarket heads, then the engine would have a LOWER VE below 2500 rpms, and would make less torque and get worse mileage.
I know what volumetric efficiency is.....
You obviously don't.
Here, maybe this explanation will help.
Atmospheric pressure is 1 bar (14.7PSI)
Let's use a garden hose and a garbage can as an example.
Let's say you had 4 minutes to fill a garbage can with a 1" hose.
Would you get it full? Of course you would, 4 minutes is a long time.
Now, let's say you had 30 seconds to fill the garbage can with the same 1" hose. Would you get it full? probably not. a 1" hose doesn't flow enough water to fill it up in that amount of time.
Now, using the same 4 minute example, what if you had a 2" hose, flowing 3 times as much water.
IF you can fill the garbage can to 100% with a 1" hose, then will a 2" hose fill it any more? of course not, the garbage can can only be filled to 100%
But, if you tried to fill that same garbage can in 30 seconds, then the 2" hose would make a huge difference.
Filling you're cylinders with air at low RPMS is like filling a garbage can with water in 4 minutes, you've got plenty of time to get it full.
Filling you're cylinders with air at HIGHER rpms is like filling a garbage can with water in 30 seconds, or 15 seconds or 5 seconds. The flow of the water (or the CFM through the head) makes an enormous difference.
remember, as RPMS increase, the "window of time" (intake duration) decreases. There is less and less time for the air to flow into the cylinder.
How "full" you're cylinders get with air is you're volumetric efficiency.
If your piston is all the way down, and you're cylinder pressure is 1 bar, than you're VE is 100%.
If you're engine moved at 1 RPM, you could have 100% VE while breathing through a tiny pin hole.
So when I say there is no room for improvement without longer intake runners, exhaust headers, or different cams, I'm basically saying that bellow 2500 rpms, the cylinders are already getting "filled" to 100% (14.7PSI absolute)
You may also ask how do the after market heads make LESS torque @ 1500 RPMS?
Think of it this way.
if you had a 1/2 HP water pump pumping water into a 1" hose. When you turn the pump on, it may take 2 seconds for the hose to fill and the water to start flowing.
If you took the same 1/2 hp water pump and pumped water into a 3" hose, when you turn the pump on, it may take 5 seconds for the hose to fill and the water to start flowing.
So if you turned the pump on for 6 seconds:
The 1' hose would fill for 2 seconds and flow for 4
The 3" hose would fill for 5 seconds and flow for 1
So in an engine, it's a trade off. Smaller valves and smaller ports will yield higher port velocities and will result in MORE bottom end torque.
