Issues with my 1996 18HP Jet Drive Evinrude
Tippecanoe
Motor symptoms (in chronological order)
1. During first outing, it would not idle with out repeated choking, had to jump into gear the second it started and crank it wide open.
2. During next outing, started, ran 30 seconds, died, restarted(jump into gear), ran 10 minutes, shut off manually, restarted, ran 5 minutes, died, would not restart.
3. I was poking around the fuel lines and one of them leaked gas when I touched it (one on bottom front of carb), so I replaced it. I also replaced the two spark plags, old ones were kind of filthy. I squeezed the ball and got it hard, then squeezed it again and a little fuel leaked from just downstream of the ball.
4. During the following outing, hopeful the issues were alleviated by new fuel line, it started first pull, and then idled about five seconds and died, and the proceeded to not even come close to starting again.
I feel like it is a fuel or carb issue, but with the increasingly worse and changing symptoms, I am not sure. Anybody care to share any advice?
jbuote
Hey there! :welcome:
Relatively new myself, but to start with, it sounds like you still have fuel line issues.
You don't want any leaks when you squeeze the primer bulb.
My initial thoughts are:
1) Is the fuel tank vented properly?
2) Does it stay running if you squeeze primer bulb when it wants to die?
3) Fuel leaking when squeezing primer bulb is a place where air can get in when fuel pump is working, which might mean not enough fuel making it to carb while running because the fuel pump is sucking air, not fuel.
4) If fuel lines are old, cracked and leaking, odds are bits of the inside of fuel lines made it into the carb and now a carb cleaning is in order.
Again, these are just some generalized thoughts.
The pros here will better guide you. Of that I have no doubt.
I hope it helps as a starting point, and I'll be tagging along to see how you make out! :D
Welcome aboard!
oldboat1
Rebuild the carb. Check the spark. Compression test. (but reverse that order)
