Issue with air coming out of water intake.
cmorg02
I have a 1977 9.9 Johnson. Third time started I notice air coming out of the water intake. Also water was coming out somewhere around the top end. I did not notice before. I did think I heard small pop from engine before I noticed issue. Tell tail was working. Thanks
Crosbyman
air or exhaust finding they way out the water intakes ?
pull the prop maybe normal exhaust flow outwards is blocked ?
is this a new sudden problem.... is this a new to you engine ...
Post some pictures or a video.-----Hard for me to think air can be coming out of the water intake !
F_R
Interesting. Of all the thousands of motors I've started in my life, I don't remember ever seeing air coming out the water intake when starting. Nor even looking for it.
cmorg02
New to me engine. Ran twice before I got it home. Was running after starter fix and I thought I heard a slight pop sound. I also notice water up high near where middle housing meets motor. Did not see first time I ran it. Could it be exhaust pushing into the water and exhaust plate.
This is going to require a video or some pictures.----Need to show where you think air is coming out.
flashback
I love it, air is not coming from any motor I know of. You see exhaust bubbles but not air.
cmorg02
Yes most likely exhaust which is air. It comes out the water intake to pump. I believe a gasket might have blown out. Just looking if sometime else. Water coming out also below motor between motor housing and lower end.
Crosbyman
I think you need the drop the GC and perform a colonosscopy up the exhaust housing
make certain the housing seals against the GC exhaust vaity ...try a sealant when reinstalling the GC.
