Is this ventilation or slippage?
WhiteRice
'96 25HP 3 Cyl. So a few weeks back I had my carbs completely Re-synced and had all linkages adjusted by an Evinrude dealer. They adjusted the timing back to exact specs (wasn't too far off) and replaced the plugs and plug wires. The motor runs with ZERO lean sneezes or backfires but the idle seems to be rough compared to what it was prior to the adjustments. The dealer states that these motors do not run very smooth to begin with at idle but open up nicely. Once I am in gear and underway, the motor seems to get back into it's element and it accelerates nicely. I have started to notice though that I either seem to be getting some Ventilation or prop slippage at WOT. This is a short shaft motor on a 16' flat bottom skiff. Basically, when the water is slightly to moderately choppy, the motor will rev up on rpms and there is a feeling of loosing momentum. Then the motor corrects itself. This only happens at WOT. The cavitation plate is pretty close (within 1/2") of being flush with the keel and this motor also has manual trim selection which means I have to stop the boat, go to neutral and adjust the trim if needed. Is there a significant difference between what ventilation and slippage feels or sounds like? Long shot, but could the link and sync have anything to do with this?
jakedaawg
Its ventilation/cavitation.
are you over revs? What max rpm fo you hold steady before cavitation?
nothing to do with link and synch...
WhiteRice
No tach on the boat. If I had to rely on "ear-balling" it I would say it over-revs briefly but goes back to normal WOT revs after about 1-2 seconds of this.
WhiteRice
Been thinking of adding a "Tiny Tach" for piece of mind though...
F_R
People like to debate cavitation vs ventilation. No matter what you call it, it is air around the prop. In your case, from ventilation.
P.S. Ole Evinrude called it a "cavitation plate" when it really is an "anti-ventilation" plate. If it was good enough for Ole, it's good enough for me.
A slipping prop hub is a whole 'nother story.
WhiteRice
Even though "The Plate" is just about flush with the keel I have 2 mounting holes left that I could actually lower the motor. Could lowering the motor help with this or should I be looking into other solutions such as a new, cupped prop or even an anti-ventilation plate?
F_R
If the ventilation is bad enough to annoy you, lower the motor a notch.
