I am in the middle of replacing the impeller on a 85 15hp johnson. I noticed there is a bit of back-lash between the shaft and the prop. Is this normal? The prop turns when I turn the shaft with no slop in the forward direction but there's a bit of slop if I hold the prop. Also, when spinning the shaft in the neutral position, theres a slight rythmic clunking sound in the lower end.
Any thought?
Any thought?
