Lyfizzfine
- Jul 6, 2001
- 9
I have a 1974 ( I THINK) Sears TED Williams 7.5 HP Model # 21758890 with a fuel problem. The motor idles ok but boggs down badly when throttled up. I tried squeezing the fuel primer bulb and the motor died instantly.Anyway i was told to check the float for sticking which i did and it was. While i had the carb off i found a small rubber red cone shaped thing with a rectangular hole in the end. This rubber piece is sandwiched between the reed valve block and the mounting face of the carb. This rubber piece has a large jagged rip in the wall of it. Is this the fuel pump? If it is does anybody know where to get a new one. I am new to outboard motors and any help would be most appreciated. Thanks Dave
