https://youtu.be/eJJEN69Oe6o
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,354 Apr 21, 2018 #2 Ayuh,..... Welcome Aboard,..... Start the motor, 'n that won't happen,.... That's the valve,....
alldodge Moderator Staff member Joined Mar 8, 2009 Messages 43,586 Apr 21, 2018 #3 Agree, and will add, adjust the flats on the on the right side where they are straight up and down. The cylinder should not be able to rotate once adjusted. Should have to loosen the cable jacket nut to rotate
