johnfergusson
- Jan 1, 2006
- 6
Hi,<br /><br />I pulled the had to look for a water leak as it has been weeping arround the head.<br /><br />It is or at least was a 1978 140 #140843C<br /><br />As best I can tell it's been rebuilt at least once probably for the same reason as this time.<br /><br />I guess it has broken a ring and the fragments have bounced arround a few times. I think bits may well still be embeded in the piston.<br /><br />This was still running, down a bit on power though. It has not run though for better than 2 years. This little suprise has been lying in wait for quite a while.<br /><br />This is the number 4 piston. Number 1 shows sign of having being rebuilt once all ready from doing a similar trick.<br /><br />I have a couple of questions.<br /><br />1 Is the non powerhead portion of the motor spare parts now?<br /><br />2 What did this? Carbon buildup? or did I not get the carb quite as clean as it should be.<br /><br />It was running with 24 deg btdc allowed up to 28...<br /><br />The starbord bores are 3.5030 and 3.5020 respectivly the port side both appear to be 3.500 but I did not have the right tool to confirm this. There apears to be some scraping of the bore and I am unsure if this can be honed out.<br /><br />Does the 030 on the pistons mean they are 30 thou over allready? or is it just a part number.<br /><br />The port head is most likely history, the starboard head shows signs of having suffered a similar problem in the past though no where as badly.<br /><br />There was also excesive clearance on number 3 piston as well and no baffles in the starboard bank<br /><br />Thanks in advance for your advice.<br /><br />The piston
<br /><br />The Head is not prety either...<br /><br />
<br /><br />And the bore is least frightening of all.<br /><br />
