Is this prop pressed rubber or solid?
jminz
Just picked it up. Was told it was pressed rubber. Appears solid to me. Which is it? It's a stiletto stainless.
fhhuber
The hubs generally are pressed in hard rubber... with a metal insert pressed into that.
You can see in that pic that the center metal insert is a separate piece from the main propeller
jbcurt00
I took the question as whether it was a pressed rubber hub or an interchangeable hub.....
