Is this normal? ......1985 20HP Johnson
Mavenite
Cranked my 1985 20 HP Johnson outboard for the first time in a few years. Hooked up a motor flusher and it started fairly easy. The cooling water was spraying from the normal pee hole on the right side just under the power head. Water was also spraying out on the left side just in front of the water intake port. I can't remember if this is normal. Please let me know if it is a problem or normal. I've attached a photo to show the location of the hole.1985 Johnson 20 hp Outboard.jpg
