Is this flywheel o.k to use?
ultra353
This is from an`89 Mercury, 40hp- 4 cyl project boat i picked up a while back. Previous owner replaced the the stator and this is how he got the flywheel off, They didn`t remove flywheel nut . Can this flywheel be safely bolted back on ( i did start it for a sec to test a replaced switchbox) and used? If so, any idea on torque for the 8 bolts and use of loc-tite, and static timming for marks, - tdc on #1 and marks in the window? Thanks
I do have a factory manual
Laddies
Banned
Re: Is this flywheel o.k to use?
It's hard to tell if it is cracked or not, if cracked it would need a flex plate kit, if it's not roll the engine to TDC on #1 and install the flywheel to the TDC mark on the cowl.
ultra353
Thanks Laddies! I`m new to merc`s and wasn`t sure as i`m used to a 1 piece omc flywheel . The flywheel looks good -no cracks so i`ll bolt it back on.
cr2k
@Laddies; Love your sig line, I see so much of this going on. Even members with over a thousand posts shooting in the dark at answers.
