Hi, new to this forum. My dad has a 1982 Seaswirl that hasn't been started since 2006. Oil wasn't changed since 1998 (yep you read that right). He fogged it well and winterized it nicely. I changed oil, filter, new battery, new oil for tilt, new drive lube in all the right places (according to the manual). Fuel had stabilizer in it so I didn't drain it. Got it started and out on the water. Everything seems to be working well but I'm not sure what the guages "SHOULD" read. The alternator guage stays right on zero. Does that mean it's not charging the battery or is it normal? Also, the temp guage has 165 in the center. It got up to 165 in about the 1st 10 minutes of operation but then it leveled out 1/2 way between 165 and the high temp mark which is 245. I'm guessing (if the guages are right) that would put the temp around 200. I ran it for about 20-30 minutes and it never moved off that temp (never got higher). It actually would drop down to about 175 when I was running real slow in a no wake zone for about 5 minutes. But once I hit it again it goes back up to the higher temp.
One last question. I "pretended" to pull a skier by being in low forward and then punching it. Everytime I punched it, it would cough and die. It allows me to ease it up from slow forward to 45 really quickly but not in one fast motion. Does that indicate bad fuel, fuel filter anything else?
Thanks for any help.
Jim
Jim
