CRT Skiff Crafter
- Aug 25, 2003
- 100
Hello fellow boat folks.<br /><br />Well, I took the old Skiff Craft (888 Mercruiser, Ford 302) up to Erie Wednesday night. Couldn't put in till Thursday as there was a full gale in effect. Thursday was a lot better so I eventually headed out to Put-In-Bay. The island was like a ghost town (kinda cool really) and I had a terrific dinner at Lad's.<br /><br />Made the return trip in the dark. Boat ran fantastic both out and back. Better than it ever has since I've owned it. However, when I hit the mouth of East Harbor and I went down to idle speed, the engine died. I changed fuel tanks and the engine started right up and ran for a little than died again. I restarted with no problem, but as soon as I tried to put it in gear the engine quit. <br /><br />I took a look for anything obvious and saw nothing unusual. Now I'm stuck in the channel and can't get the blasted thing in gear without killing the engine. Even tried reverse with the same result. <br /><br />I was getting pretty desperate so I attempted to start the engine with the drive already engaged. <br />Fortunately, it started and would run in gear at idle, but would take no more throttle without dying. So I was able to cripple it in this way. <br /><br />This morning I had the marina service manager have a look and a listen. With it secured to the dock, we started it and put in gear and it did not die. We tried this several times and it seemed just fine. So we listened to the gear housing, moved the drive from right to left and again everything seemed OK. <br /><br />Well the weather was going to get crappy and stay that way for the next week, so I decided to come home. When I drove the boat over to the launch ramp, it started doing this again. I barely got it there.<br /><br />As most of you know, this engine has new timing gears & chain, breakerless distributor, plugs, plug wires, coil, carb rebuild and it was running like a champ. Before I left for Erie, I had a gimbal bearing put in. And I did fill up with gas at the marina at Erie. <br /><br />The engine starts perfectly and will take throttle as long as it is not in gear. Put it in gear and it get's very unhappy. I have never experienced any symptoms like this. <br /><br />What I'm wondering now: Bad gas? Distributor (timing advance)issue? Did something happen during the gimbal bearing install that put a bind on something else? Low grease in the drive? <br /><br />Help me I'm drowning - glug, glug...<br /><br />Regards, crt
