Is there any reason for a drain plug to have a screen?
Status
Not open for further replies.
chuser
I was washing out the boat today. I pulled it up on the floating dock and unscrewed the drain plug. However it didn't work very well because it kept getting clogged with debris. I looked and the drain plug had a fine mesh screen. It's recessed 3/4 inch in the plug, not on the outside where it would be easily cleanable. I kept sticking my fingers in there and moving the debris around so it would drain.
Is there any reason to have this? Why wouldn't I want things to flow out, sticks, leaves and all? Should I just try to bash it in?
Texasmark
I'd think it is a mis-application to coin a popular politically correct word of the day. Not rocket science to know that bilges collect this and that. If you were talking about a fueling funnel, then as you are suspecting, yes, you want to trap foreign objects....but a bilge drain? I would.
jbcurt00
Sounds more like a livewell fill plug not a bilge plug...
What boat?
Any chance theres another plug?
chuser
I wish our boats showed up on our user badges. It's a 12' bare aluminum jonboat. No upholstery or anything inside. I just dumped water in, washed the sides, floors, and seats, and let it all drain to the back. It's not a bilge as there is no empty space under the floor, just bare aluminum everywhere. It unscrews from the inside not outside. Definitely no other plug, it's right where a drain plug should be at the lowest part of the dimple at the back of the boat. I wish I had taken a picture but I was so tired after finishing all the scrubbing I just shoved off the dock and left.
Ayuh,..... Take a stick, 'n knock it outa there,...... No reason for it,.....
I've never seen a bilge plug with a screen. It doesn't even make sense to me. Why can't you remove the plug to let everything drain out? Unless you are saying that there is a screen in the outlet, just replace the current bilge plug with a standard one without a screen.
If there is a screen in the outlet, I would just knock it out of there. On my 12' aluminum boat, I keep it on shore with the plug tied to the gunnel with a rope. When I turn the boat over to use it, I scoop a bucket of water out of the lake and send all of the pine needles and spiders down to the bottom of the boat and through the outlet. I then put in the plug and show the boat into the water. You should be able to do that too.
Ayuh,....... That may well be where his screen started it's life,......... Bilge debris,.......
Old Ironmaker
Strange stuff one reads here occasionally. Can you take a photo? The plug should be nowhere near the hole when you remove it, like in your pocket. Do you mean there is a screen in the hole not the plug?
chuser
The stopper does not have a screen in it. The plug that it screws into has a screen.
bkersh1
If anyone happens to read this thread, I want to clear something up about some drain plugs. I have a 2018 Sea Ray 21' SPX outboard. I noticed that no water was coming ouy and would be pushed out by the bilge pump. I too saw a mesh screen when I unscrewed and took out the plug. I took out the 3 screws holing the garboard. It was a one piece safety drain plug, I showed this to my mechanic (of 40 years) who said he had never seen anything like it. It was approx 3" long with a protective screen on each end of inner chamber and part of the plug. I removed it and put it in a normal brass plug.
MODERATOR EDIT: Please review the forum rule about posting to old threads.
Status
