1978, 165HP Mercruiser I6. Fired up the boat at the launch ramp, no problem. Slow idled out passed the no wake zone, no problem. Hit the throttle, boat starts to get up on plane, then....Klunk, the engine just dies. Acted as if the coil wire to the distributor just popped off. So I lift the engine cover to check but everything looks ok. Try to start again but engine just cranks. Fuel is getting to carb, so I check for spark from the coil....nothing! Take the distributor cap off to look inside (for what? I don't know
). Had my buddy crank the engine and I can see the points opening and closing and sparking. Is that possible? With no spark from coil?
So I put the cap back on, check for spark from coil...and surprisingly this time I have spark. Button everything back up, go to start the engine...cranks, but no start. So I go back check for spark from coil, and again NO SPARK.
I take my pliers and give the coil a few whacks (out of frustration), check for spark...and surprisingly I GET SPARK. I quickly reconnect coil wire to distributor, turn the key, and the engine starts.
I ended up going back to the docks, running to the parts store for a new coil to have in the boat...just in case. Got back, fired her up went fishing all day, shutting her off and starting her up several times, no problems.
So my question is, do I have a bad coil? Can they go bad intermittently like that? Should I have gotten spark at the points with a bad coil? Did I move some wires or connectors that finally let the boat start? Would this problem have anything to do with my ignition cut-off switch? I really don't want to get stuck out on the water again.
