The engine sometimes stalls when idling. Is it easy to be fixed?
Two famous words, "It Depends".
If you intend to actually do maintenance and repairs to your boat, there are five key things you first must understand how your boat functions:
1. Fuel. How does the fuel system function for your boat in keeping the engine running? What happens when too much fuel or not enough occurs?
2. Spark. How does the ignition system affect the boat engine while running?
3. Compression. How does the boat engine build and maintain compression for the combustion phase?
4. Cooling. How does the engine remove excess heat to keep the engine running? What happens when the engine overheats?
5. Drive system. How does the drive system of the boat convert the engine power into forward and reverse movement?
No one can learn it all instantly, so it would be beneficial first do some research on how a four stroke motor works and how a typical four stroke carburetor works.
If you don't do research, everything is going to seem like rocket science and foreign.
Those that ignore this get frustrated because the expert advice given to them wasn't a quick fix solution.
You either spend the time and effort to learn, listen, and do it right, or pay professionals who are trained to work on it.
