Is oil leaking normal? I am guessing not.
aewood21
Bought a used boat on Craigslist. Had it out all weekend and it did great. However, now that it has been sitting in the yard for 2 days (with motor trimmed all the way up) I see oil leaking out. Are any of these major concern? The first worries me... the second not so much.
There has also been a bit of a gas/oil mix running down all weekend from here. You can see it seems like a very small amount to me.
Thanks for any advice.
billsfw
Re: Is oil leaking normal? I am guessing not.
#1 unburned fule and oil. Ok
#2 disconnect the fuel line. will be Ok.
aewood21
Thanks. That puts my mind at ease... and it makes sense.
levi_tsk
Ensign
you can go one step further if you like ... put a vacuume cap where the fuel goes into the fitting this will stop it leaking all together AND keep critters and dirt out
