Khanhfucious
- Jul 8, 2006
- 32
Ignore the metal shavings on the ground (I drilled out a broken bolt to put in a new tilt stop bracket), the retaining wall blocks (I had those under the thing behind the prop (skeg?) while I was working on the bracket), and the bend in the transom saver (I didnt have that green strap and it bounced out of the roller, dropping the motor)
