hornetswarm
- Jun 9, 2011
- 33
FYI- I replaced all seals that I could without taking any gears out of the lower unit. Now it looks like my bearing carrier has rotated in the housing. Seems like the holes should be perpendicular to the skeg....your thoughts....
FYI- Lower unit is fine- no leaks, gears are good, no play, shifts in and out of gear....my only problem is water flow.... I think the bearing carrier rotated has made the flow of water not correct..
My engine is a Force 125HP 1989 "L" drive...
