I just bougth a BEP Marine CMP-5WPS switch panel and buss bar from iboats. The switch panel has five switches plus a built-in 12-volt accessory socket. It has 4 ATM fuses.
The pre-wired positive leads coming from the panel are 18 AWG wire. According to the instructions, it appears that I am supposed to run a heavier wire from the battery to a wire nut-type device that was included with the switch, and then run two 18 AWG wires from the wire nut to power the switch panel.
My plan is to run 10 AWG from the battery to the wire nut, and then run two 18 AWG wires from the wire nut and butt splice them to the pre-wired switch panel leads. Also, I bought a buss bar from which I will be using 10 AWG as a ground wire back to the battery. I will be powering normal small boat-type stuff (e.g. nav lights, fish finder, courtsey light, etc.)
My concern is that the switch panel, including the power socket, will be wired using "only" two 18 AWG wires. Does anyone see any problem with this?
Thanks.
Thanks.
