Is my mercruiser a aplha 1? How do I tell
ctaylor2069
I just got a 1985 century with a mercruiser 3.7. I believe it's a alpha one. How do I find out for sure? I'd like to order a water impeller kit. Thanks
Bt Doctur
It the drive is held together by nuts ,its Alpha
If the drive has 2 nuts and bolts on each side its a Alpha GEN II
ctaylor2069
I have another question. On each side of out drive there are to electronically controlled "things" what are they and what do they do? The wires going to them are broke
ctaylor2069
I believe it's the trim sender. Which would be why my gauges for the trim do not work . can't upload pic
nola mike
Ones the trim limit switch, the other is the sender for the trim gauge
ctaylor2069
Ok well they are both broke. Could that be why they wired a aftermarket switch? The factory guage and switch so not work
