Is my Ford Edge have enuff Capacity to pull my new Crestliner
Viewout
I am getting a newer Crestliner at the end of march and was wondering if my 2007 fwd Ford Edge would have any troubles pulling the boat and getting it out the water Crestliner 2003 1600 Angler SC I was told that my Vechile weights something like 6k or around that. also just got a hitch attached, just want to make sure.
ezmobee
Re: Is my Ford Edge have enuff Capacity to pull my new Crestliner
Your edge should have no issue whatsoever towing a 16' aluminum boat. You'd be WELL within your tow rating. Enjoy!
jkust
I don't know the Edge other than by recognition but is it AWD or 4wd? If not, I have seen the most robust full sized trucks not able to get their 14 foot row boats out of the water at heavily used ramps with just 2wd and even with a rear locker. Other than that issue, it takes very, very little to pull a boat like the one in question out of the water. It take very little to pull even a good sized/heavyish boat out with good ramp conditions.
3dees
I pulled my 19' crestliner all last year with a 2008 Ford edge 2wd without any problems. it's rated for 3500 lbs.
Outsider
I think you'll find your Edge is closer to 4k than 6k ... ;)
NWVintage
Check on the weight of the boat and the weight of the trailer. Add them together and make sure that the number is less than your towing capacity. Also be careful if you have an automatic transmission with that aftermarket hitch - a factory towing package will usually include a transmission cooler on an A/T...
Other than that, just use good judgement. I have towed things far in excess of the towing capacity with my 1983 Toyota... But I have a hitch that's "not compatible" with my truck (had to grind an exhaust mount) and is rated for 6k, with rock-solid suspension (no stupid-*** lifts here). My weak link is the brakes - I go slow and stay way back...
jkust
Also, since we've gone down this road before, tow capacity isn't the end all either. The weight of your truck passengers, truck gear, truck gas, etc, can erode the actual tow capacity. It seems some vehicles owner's manuals calculate it differently.
At the end of the day, my biggest concern that gets overlooked in the excitement of wanting to get to the ramp is the on- the-road margin for safety. When things go fine, all is well, but it's the outlier situations while towing to me is where the problems can occur. I've owned 4 tow vehicles with my current sig boat and when I first got the boat I only had a low power, old, front wheel drive minivan not rated anywhere near the 4000 lb wet weight taking into account the full passenger load, plus a lot of cargo and gas in the van. I didn't care and got to towing as fast as I could hitch it up. It only took a couple incidents to see the problems that can occur towing with that particular unibody vehicle. It had air springs that really masked it's weeknesses plus the full tow package. Like I said before it pulled it out of the steepest ramp imaginable fine with the same effort as pulling into a parking spot but what it couldn't do is high speed maneuver well when the idiot pulling the trailer full of hay pulls out in front of you while you are doing 60 and the minivan has the huge benefit that it is as long as a suburban. Since learning how not to tow with the minivan, I've owned three full on v8 suv's/4wd with the works and it was like being blind and suddenly being able to see the capability difference is so immence. It was really the iBoats people that opened my eyes.
NWVintage
Exactly, jkust! I just re-read my post and realized that I didn't put this flip-side to the whole "just be smart" line. At some point, auto makers changed the way that they do towing ratings and while some of the older vehicles are really underrated, some of the newer vehicles are similarly overrated. For example, my mom's 2007 Jeep Grand Cherokee is rated at 6k towing and my 1983 Toyota is rated somewhere around 1300 (max recommended gross minus weight of vehicle); I'd sooner tow 4k with my Toyota (over 2x the rating) than I'd tow 6k with the Jeep (the actual rating). At some point, the towing rating system became much more liberal. You simply have to be careful, drive alertly and defensively, be careful, know the limitations of your tow vehicle and be careful; if you feel unsafe, you are.
All of that said, I live 3 miles of 35mph from the ramp that I use 98% of the time, so my issues are different than many. I rarely tow at freeway speeds...
H20Rat
This counts for far more than any tow rating! An experienced driver can pull something that is technically over the tow rating and do it with absolute safety. A careless and new-to-towing driver can be a road hazard with a tinny behind an f350 diesel. People tend to forget that it isn't the brakes, engine, or tires that are the weakest link in towing... The nut behind the wheel is the weakest link.
