tasmania105
- Aug 22, 2010
- 19
First of all I would like to introduce myself. My name is Jaime and I'm from CT, I recently purchased a 1986 Bayliner with a 1986 85HP FORCE outboard motor which was tested by a mechanic on land with the earmuffs and running water.
The problem that I just ran into is that when I tried to put the boat in the water, it starts right up and idles fine like the mechanic said, but when I want to shift into reverse or forward the engine seems to stall.
I would appreciate if you guys would give me your personal input on this subject or even if this has happened to any of you in the past and how I should go about fixing this problem. Thanks for taking the time to read my post and I hope that you guys can be of great help.
