Is mounting motor like this OK ?
Moody Blue
I have a 1993 40HP mariner OB that has been fitted to a 14ft fiberglass whaler style boat. In order to align the cavitation plate with the hull bottom, the motor is sitting up off the top of the transon by about 1 1/4". The motor of course is bolted thru the transom at 4 spots but I am concerned that the bolt holes thru the transom are taking all of the shear load. Should a spacer black be installed between the top of transom and motor bracket?
dajohnson53
Re: Is mounting motor like this OK ?
I have no idea if it's correct, but I've definitely seen motors mounted like yours with a block taking up the space. I've also seen a lot of motors mounted with the space without a block.
D
DJ
Guest
Don't worry about it. The four bolts are taking the vertical as well as the lateral load.
Chris1956
RodC, My speed boat (150HP Merc, 16' Avenger) has the motor mounted 1-1/4 above the transom. I used a 2X2 pressure treated pine, ripped to 1-1/4 for the block. The thing I would worry about is the transom bolts ripping out, if they are too close to the top of the transom. Id not, you are likely OK. I am considering installing a manual jack plate so I can lift the engine more, aince I am afraid to install a taller block. The Anti-ventilation plate is only about 1/2" above the bottom of the boat.
quantumleap
Master Chief Petty Officer
My 125hp is mounted like you describe with no block. Larger stainless backing washers were added and it is fine. I contemplated using plates such as these http://www.cook-mfg.com/accessories.html but decided not to. I've seen many motors mounted in that manner so I don't believe it's a problem. Even with the top of the mount hooked over the transom, the front edge of the hook doesn't always touch the transom anyway. Don't sweat it.
Moody Blue
Thanks everyone for the feedback. As suggested I am going to leave well enough alone and enjoy the ride. There is a 1/4" aluminum plate on the inside of the transom about 16" wide x 14" high. I guess that should be more than sufficient.
