I have a 1988 88Hp SPL. I got it out of storage and by some small miracle it started right up and seems to idle fine. I noticed while running it in a tank that that exhaust gasket is leaking at the bottom and blowing bubbles in the water that pools up a little in the lower engine cover. Two questions: Is a leaking exhaust cover gasket something that needs to be fixed immediately? Is the small amount of water that pools in the lower cover from the leaking exhaust gasket, or should I look elsewhere?. Thanks for your help.
