Jeffneal1988
- May 1, 2013
- 25
So I have been having issues with my Tilt and Trim. When I press the button the motor runs but does not lift the motor. I can lift the motor up but it doesn't hold itself in place it just comes right down. I found a little leak underneath one of the cylinders where the line connects to the tee. I bought a new tee and I cant even get the lines to line back up correctly. So I've been calling around to some Marine shops and one of them told me it's not even worth fixing it because its so old. The motor it a 74 115 hp Evinrude with an add on tilt and trim. He suggested to get a cmc tilt and trim but of course it's $600. I had one shop said they would look at it and they charge 85 per hr. I'm just confused as to what to do. I cant even run my boat because when the tilt and trim was added they removed my engine lock mech. I have no clue when it comes to boats. I've heard it could be the release valve is bad but then again I have no clue. I just bought this boat in the winter and it's my first but I cant even use it. I am going nuts any insite to this would be great!!
