is it just me or could we .....
KRS
Banned
Could we spend the entire year performing boat maintenance without ever hitting the water?<br /><br />I read the factory manuals and I think... I'M SUPPOSED TO BE DOING THAT HOW OFTEN!?!!?!<br /><br />Anyone else get overwhelmed with it all?
Kalian
Re: is it just me or could we .....
Yes, especialy since I own a force! They're not as forgiving as most other OB's.
heycods
I can think of 47 things I need to do to my boats<br />I need a round tuit, ;) It will warm up and not have 50mph winds and dust someday. I did get around to putting on the muffs and running them last week. I had high hopes of fishing a bunch this spring. But it apears Im moving in the in-laws instead. I love them to death but I do see them cutting into my boating time. :(
Fly Rod
:) Do my maintenance in the month of April and do not do another thing to it unless it breaks down, which is hardly ever!!!<br /><br />Work schedule: bottom paint;check and redo wires if needed;fuel filters;oil filtor;check anchor line; up date flares if needed; new plugs; check batteries and replace if needed and replace on the 3rd year!!!! Did have a fuse on the motor blow at the end of summer!!!! ;) :cool:
KRS
Banned
I need a round tuit too!<br /><br />That's a hefty project list Fly Rod.<br /><br />The motor/drive alone can take up serious time for a budding boat do-it-yourselfer.<br /><br />Remove the leg, change impeller, change oil, grease ujoints, replace bellows, water line, grease coupler spline, grease prop shaft... change crankcase oil, check plugs, keep the metallic air cleaner constantly clean as it seems to be a dirt magnet (better than dirt in the engine!), oil filter, etc.<br /><br />It's a lot to do I think... probably a few times experience doing it and it will take half of the time though.
salty87
i know you guys like your ob's and i/o's but my inboard sure is easy to take care of.<br /><br />remove the leg?...sounds like a bad prognosis, doc. can i get another opinion?
