martiniman
- May 24, 2011
- 2
I have a 1996 Steiger Craft Chesapeake 21 with a 130 hp, 3.0L 4cyl. Alpha 1, Gen 2 Mercruiser I/O and I get no alarm when turning the key. I'm fairly new to I/Os, Does anyone know if the alarm system came standard on the 1996 model? I also notice the fuel gauge is not working, could this be tied into the alarm system with a sensor? I'm being told by my mechanic that I should put a new SEI outdrive with 3 year warranty, $1400! All this after spending $1000 on all new outdrive seals last year! Why would gear oil get low if the seals were just put in? The boat stopped while underway, when looking at the engine, the gear oil reservoir was empty. Mechanic said fishing line wrapped around prop shaft caused the engine to shut down while under way. Could this cause gear damage? Gear Oil was low and exposed the upper bearing. the quote to fix is $1100. I'm thinking of going with the new SEI outdrive but I want to make sure a warning system is in place after spending the money. Even if I have to add one. Any suggestions?
