Re: is a thermostat neccesary?
Running without a thermostat can cause a poor idle at the least, or a scuffed piston, and damaged cylinder wall at the worst. With out a therostat, the engine can have a cold siesure, this is where the piston is running hot, and expanding, and the block is running cold. This usually happen's at idle. At full throttle the parts equal out, and engine has full coolant flow. If an engine overheats with the thermostats in, there is a restriction some where, or exhaust gasse's are leaking into system. Taking out the thermostats is just putting a band-aid on the problem.
