Is a Junction box really necessary?
iboat2011
Hello,
I bought a 62 40HP Johnson(RDS-24M) recently. The generator is missing and junction box seems to have parts missing too. I am just wondering, are generator and junction box really needed for that model?
Thanks a lot!
Andrew
lindy46
Re: Is a Junction box really necessary?
No, not needed. You could mount the starter solenoid under the hood and wire direct to the ignition switch and battery. The junction box provides you with an easy quick-disconnect at the motor via the plug, and you would lose that convenience. But if the motor is permanently mounted on a boat, it really doesn't matter that much.
royal0014
Master Chief Petty Officer
Nope. On my RK-28 everything is under the hood, including the voltage reg. Just takes some ingenuity and wiring know-how.....
iboat2011
Just want to confirm, if I do not have generator, I do not even need voltage regulator, right? Thanks a lot!
xtremefisher1
i have the same thing and was wondering the same idea but i posted mine in the eletrical part.. i am wondering if someone could give us both a diagram as to how to wire that up with out the junction box.. i am not trying to steal a thred but i beleive this would both help us out..
if i wanted to go to a bigger box for more work area does it have to a a metal box or can i be at plastic one with weather proofing on it?
thanks
F_R
Wiring is the same, no matter where you put the stuff.
1946Zephyr
A need for a junction box will greatly depend on what you have and what kind of electronics you have installed. In your case, since you have a 1962 40hp, without a generator, you can mount your electronics, under the hood of the outboard, and not be worried about rust and corrosion. However, in that model of motor, you do have the option of upgrading your electrical set up and adding a generator and voltage regulator, so you will then find a need to find a water tight box to mount near the transome of your boat to hide all this stuff. I happen to own an Evinrude 40hp of your vintage and have worked with several of the same class, so the option is yours, as to wire it up for a future application of a charging system or not. If not, then mount the starter solenoid and stuff under the hood of the motor, otherwise, get a larger junction box, incase the desire for a charging system later comes around.
Mas
The regulator is only needed with the genny.
Mas
F_R
The junction boxes are a far cry from being waterproof. In fact, that was the biggest problem we had with them. Get some water in the bilge, and it slops up at the transom during acceleration, swamping the junction box. One or two times of doing that and you have a box of junk, if used in salt water.
Mas
Then it should be called a "junk-sion box!"
Hee hee
Mas
1946Zephyr
A water tight Hoffman box will cure that :D
samo_ott
Here's how I put the solenoid in my '62 25hp this summer.
