is a fleetwin 1954 carburator kit fit a 1953 fleetwin
mick2000
is a fleetwin 1954 in 7.5 hp carburator kit, can fit on a fleetwin 1953 in 7.5 hp.
Chinewalker
Re: is a fleetwin 1954 carburator kit fit a 1953 fleetwin
No, the '54 uses an OMC made carburetor, while the '53 uses a Tillotson... Very different carbs.
mick2000
where can i find a carburator kit for my fleetwin 1953 7.5 hp model #7512-65789
F_R
Nearly impossible to find a "kit", but some individual parts are still available from Evinrude. Do you have a parts book? You will need one because the dealer probably doesn't have one either.
Chinewalker
Carb parts listing...
mick2000
i am lost, i don't know really what part as to be change. maybe only spray the carburator with carburator cleaning fluid.
i know i need a float bowl gasket it is broke. but for the rest i don't really know. i never do this before.
but will like to order all parts from one place, if they have them all.
thank you for your help.
Chinewalker
Not likely. You have to improvise sometimes on nearly 60 year old outboards. Gaskets? Get material, some sharp, fine-point scissors, and a hole punch set. Float needle? Might find something from another motor that is similar in dimensions.
mick2000
i see this on iboats
Sierra 18-0116 Gasket Material
is it the gasket material needed?
for the Float needle, how can i know if this part still good
1946Zephyr
Yea, like Chinewalker said, the '53 and older Fleetwin uses a Tillotson carb and parts will be a bit tougher to find. You can try Sea-Way Marine or Engine Blade and Prop. It seems like these two places have the best supply for older motors. The Tillotson carb on your motor looks very similar to the later style, but not quite the same. Oddly enough, the mounting is 90 degrees off and the low speed jet is opposite. I think you can get by with your original needle and seat, if you can't find one, but you'll want a new bowl gasket.
samo_ott
Just make a bowl gasket. Most gasket material will work of the same thickness. And I have the parts manual I can email if you want it. If yes, PM me your email address and model #.
