Hi, I have been lurking here in the forums for some time but this is my first post here. I have a 79 model 70 hp Evinrude 3 cylinder.
I purchased a new depthfinder and got it installed today. It has a readout for the voltage. Is shows 12.6 volts when the engine is not running. It reads 16.5-18 volts when going down the lake. Is that a problem?
For some time now my tach works sometimes and sometimes it doesn't. I have used the instructions I found here for testing the rectifier and it check out good. Does my engine also have a regulator that could be bad?
The engine runs great and has no problems. Should I be worried about the high reading on the voltage? Should I stop running the boat because of the high voltage readings?
Thanks in advance for your help!
