winbasic
- Jul 4, 2006
- 125
Hi,
I've recently had some electrical work done on the boat which included adding new house batteries, Voltage Sensitive Relay and installing a DC meter. After numerous problems with the DC meter which were finally rectified, I'm loathe to go back to the shop who did the work for fear something else will get knocked out - fix on system, stuff another seems to be the service on offer unfortunately.
So the setup I have is 3 x 105ah deep cycle batteries joined together for my 12v house supply and a separate AGM starting battery. I have a 1500watt inverter connected to the house batteries. The DC meter is connected via a shunt to the house batteries and the VSR was installed so that when the Starter battery is fully charged it automatically diverts alternator charge to my house batteries.
Everything appears ok now except when I use the inverter. If I turn it on, when I touch my stove, it is 'live' - 12v live I'm assuming as if it was 240v I don't image I'd be typing this post!!
If I plug my generator into the shorepower plug, nothing is live. If I just use the 12v supply, nothing is live - its only when the inverter is turned on and it only appears to have happened since the work was done on the electrical system. I'm assuming that its something to do with where the earth cable is located (or perhaps not located) but have no idea where to start in tracking this down.
Hope someone understands my rambles and can point me in the right direction - I'd be most appreciative!!
