Re: Inverter Generator For Boat
I have done much research on this.
An Inverter Generator will idle at different speeds depending on load a normal generator will be ideling at full speed.
Like others said watch for CO, never sleep with it on, never put in the cockpit, never put on the bow (boat points in to wind, wind passes CO to cockpit) Swim platform is safest place
Add a CO detector to cockpit and another one to the cabin
Close cabin when running
1,000W for normal loads, you will need 2,000W if you plan on running AC. You will not be able to have everything on with the generator so pick what you want to use IE it will trip the breaker if you have A/C on, Stove on, and microwavw at the same time
You will need one of these:
Amazon.com: Marinco Marine Electrical Shore Power Pigtail Adapter, Yellow: Sports & Outdoors
Never store generator or gas in locker.
Honda eu1000i and eu2000i are the best you can get. eu1000i will set you back about $799 eu2000i will set you back $1000. I don't have $1000 for a 2000w generator so I am going to get this later this week:
2200-Watt Digital Inverter Generator-RYI2200 at The Home Depot
They have it at my local homedepot, I played with it the other day good reviews, good size, i can carry it and the price is only $699
Many people use a generator on a boat and have no issues, watch out for the CO and like I said before NEVER SLEEP WITH IT ON. Have two CO detectors below and one in the cockpit and always have the cabin door and hatches shut when using. There will be people who tell you if you use a portable generator on a boat you are going to die and go to the 7th circle of hell and there are people who say it works just fine and is safe, you will have to decide what is best for you.
Hope this helps. h
