Re: Intrument/Dash Panel Replacement
Art was layed out in Corel 9, any half-decent graphics package you have should do. Next is a visit to a sign shop or graphics house, ask them if they can output onto Lexan film. If yes, find out what format they need/want. Don't forget that the image must be reversed because it will be printed on the back of the film to protect it from scratching. Next take your old pane; to a plastics shop and have them cut/router a new panel using the old one as a template, you should use white acrylic or lexan, so that the colours on the new dash will be vibrant. Once you have the acrylic/lexan return to the sign shop and have them laminate the film to the new panel. I am located in souhwestern Ontario and have a pretty good handle on suppliers around here, not sure where you are or what the resources are, I'd be happy to share more if you need it.<br /><br />Good luck
