Hello & Thanks in advance for any help you can provide. I have a 1999 9.9 hp 2-stroke Merc OB. The motor was purchase new but has 10-15 hours on it. I rarely use it. The water stream comes out of the top of the motor in an intermittent stream. Pretty steady & strong at low trolling speeds. When I speed up toward full power the stream becomes irregular. It will squirt for 5 sec on and 5sec off.<br /><br />I tried changing the thermostat and blowing out the rubber supply tube from the thermostat to the outside of the motor. No obstruction of any type noticeable.<br />I just picked up a new impeller to try. The local dealer said changing the impeller was easy even for the non-mechanic type. What do you all think.<br />Thanks Fish'n101
