Hi everyone, I'm new to this forum / boating and need your help. I searched the forum and can't find anything similar to my problem. I just bought a 1975 9.8HP outboard motor to server as a kicker for my 18' boat. At first when I ran the motor in a trash can I get a stream of water out of the pee hole, but when I rev the motor up the stream stop and I only get exhaust / air out of the pee hole. In order to get water out of the pee hole again I have to shut off the motor and restart it at idle speed. Is this common or should I be getting water out at every RPM? Or maybe the motor have to be moving in the water to get enough water into the inlet hole? Also I can't seem to find where the water suppose to enter the water pump (inlet hole) of the motor. Please advise. Do I have to change the impeller or is this a common thing where the water is not entering the motor since it is in a test tank? Thank you ahead.
