I have an intermittant spark issue on a Johnson 60ESL70B. There is at times no spark on any plug. A friend gave me a generic test proceedure to follow. while I was looking over the engine all I looked at was the inline fuse, I tightened down a purple wire with a ?? color stripe that I later traced back to the choke, pulled the boot off the coil wire and wiped the dirt off the coil wire that goes to the block of electrical connections. My helper tried to start the engine while I was off doing something else. The engine was running when I came back. Now this morning, it does not spark. This happened once before-running fine and then no spark.
Is it possible for the coil to only fire intermitenttly or if it stops it is dead? Can I remove the coil wire from the distributor cap and use a spark gap guage to test that it at least fires?
