Hello,
I have a 1969 mercruiser 160. I took it out for the first time this year yesterday. The motor runs like a top. After about 40 minutes into a ride, at about 2500rpm the motor started making a "knocking" sound. I shut it down immediately. I looked at the oil for water or gas intusion and didn't find anything. It appeared to still be full. After I let it cool down, I decided to fire it back up and just putt-putt back home downstream. The knock was immediately there again. However, running between 600 and 1100 RPM the knock is intermittent. It does not sound like a lifter tapping. It sounds like a KNOCK. It sounds like upper motor, though.
After reading some posts about another identical sounding problem a couple years ago. I started thinking about this post.
http://forums.iboats.com/showthread.php?t=47167
The motor stills runs like a top, no hesitation, all six cylinders running well, just the intermittent "knocking". Although it knocks more than it doesn't.
I pulled the fuel pump and the spring is not broken, but seems 'a little weak'. I suspect that it is original to the boat. I know-I should probably just replace it now. But I don't like just blindly throwing new parts at a problem. What do you guys think? Is this probably the right first step?
http://forums.iboats.com/showthread.php?t=46972
If I do replace the pump, and it doesn't fix it, what are steps 2 and 3?
Illerad- does this look like same symptoms and same suggested remedy?
Thank you to anyone who takes the time to read, think about it, and post.
