I have a 1997 Starcraft pontoon boat, Mercruiser 3.0 , with an on again/off again starting issue. Last year I turned the key, nothing happens. Later on turn the key and the engine fires up. Next week same issue, nothing. The first mechanic changes the starter and it works , then next week the same issue, nothing, like the battery has been removed. Battery has 12V. He thinks it may have a crimped wire. He keeps putting me off on working on it, so I take it to a second, highly recommended, mechanic. He changes the already changed starter, and it runs for a while, then the same issue crops up. In the meantime I have carb issues and have to have it rebuilt. Once thats done, I take it out on the lake this past weekend, it starts right up, and I run it for about 30 mins with no issues , and when returning to the dock I throttle back to idle and it dies. Turn the key and nothing, not even a click. I manually load the boat, and after pulling out I decide to see if the trim will go up, so I turn the key just enough to get power to the acc and the trim goes up fine. Try to turn the key to start it and it clicks but doesnt turn over. Second try same thing, a click but no ignition. A third and fourth try I get nothing again, no click, like the battery is removed.
I'm thinking replacing the key switch is a good start, maybe replace the wiring from the key to the engine, but after that I am out of ideas, and both mechanics seem befuddled. In their defense it started both times I picked it up, so I guess if it isnt doing anything wrong there isnt much way to find the issue.
Any ideas or solutions from having the same issue would be appreciated. As it stands I am going to change the key switch, then start taking readings with a voltmeter to see if voltage is stopping short somewhere.
Thanks
Thanks
