Re: Interference noise in speakers
The filters are the best first fix, if it still doesn't go away you need to check the grounds that are feeding your components. If they are all grounded together, you need to separate them and individually ground them. Also, if you can, try to make the ground circuit as short as you can. Also, do not have power wires attached to speaker or RCA cables, like taped together or zip tied together. This can cause the wire to get interference directly from the power wires.
