toneeees
Administrator
- Mar 15, 2011
- 3,024
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]
Since summer has arrived and boating across the county has resumed, it is important for boaters to understand and follow safety tips. Summer is the peak season for thunderstorms. Follow the simple advice given in this article, and you will help guard yourself and your boat from being struck by lightning.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]What can happen if my boat is struck by lightning?[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]If a boat is struck by lightning a couple of things can potentially happen. The strike can completely wipe out a boat's electrical system and destroy the engine. It can also burst a hole through the hull in an effort to reach the ground. Worst of all, it can end a human life.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]How can I prevent this from happening to my boat?[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]The best way to prevent your boat from being struck by lightning is to avoid being on the water during a thunderstorm. You should always check your local weather station before heading out on the water, and if the weather becomes threatening get to land as soon as possible.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Another helpful skill for boaters to learn is reading the weather. Boaters should watch for the development of large well-defined rising cumulus clouds. A cumulus cloud has noticeable vertical development and clearly defined edges, and is often described as cotton-like. If the clouds become dark and more anvil-shaped, this means the thunderstorm is already in progress. Also watch for lighting in the distance and listen for thunder as you see the clouds start forming. Thunder travels one mile per five seconds.[/FONT]
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]You can also help prevent lightning from damaging your boat by installing a lightning protection system, also known as a bonding system, in your boat. This system helps direct the lightning's path to the ground (water,) away from passengers and major components to at least minimize the amount of damage or altogether prevent it. The system uses a main conductor to send the strike to an underwater metal plate, which is usually constructed of copper or some other non-corrosive metal.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]How will my boat insurance help if my boat is struck by lightning?[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]If your boat is damaged by lightning, then your insurance should cover it. However, it's important for you to review your coverage and know what your insurance does and doesn't cover. Depending on your policy your boat will either be repaired or replaced. No boat owner should be without insurance. For a free no obligation quote, call NBOA Marine Insurance 1-800-248-3512.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]NBOA Marine Insurance is a purveyor of value: quality, impeccable customer service and competitive insurance rates. We say it time and time again, at NBOA Marine Insurance, our marine insurance agents are also boating enthusiasts. We have extensive knowledge of the water, and have made it a priority to educate the marine savvy on the many things we have gathered throughout the years.
[/FONT]
Since summer has arrived and boating across the county has resumed, it is important for boaters to understand and follow safety tips. Summer is the peak season for thunderstorms. Follow the simple advice given in this article, and you will help guard yourself and your boat from being struck by lightning.[/FONT][FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]What can happen if my boat is struck by lightning?[/FONT]
[/FONT][FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]You can also help prevent lightning from damaging your boat by installing a lightning protection system, also known as a bonding system, in your boat. This system helps direct the lightning's path to the ground (water,) away from passengers and major components to at least minimize the amount of damage or altogether prevent it. The system uses a main conductor to send the strike to an underwater metal plate, which is usually constructed of copper or some other non-corrosive metal.[/FONT]
[/FONT]
