Re: Instrumentation for GM 4 cyl inline
Sending units? Wiring? Since it is a Chevy engine, use automotive or marine gauges? Any ideas and wisdom appreciated.
You basically need:
Some wires
2 gauges
2 sender units
You probably have plus and minus in the instrument are.
Pluss and minus to each gauge.
(pluss instrument light if you have ore want)
And one wire for each gauge to the sender unit.
You have a switch today, change the switch for oil and water with sender unit.
Check range on gauge and sender, if you go for not OEM products.
(240-0 ohm for oil sender unit, Mercruiser) I think
(180-10 ohm for water sender unit, Mercruiser) I think
Maby not a problem in US, but big problem in Europe.
Sender and gauge, must have same range.
I your engine only have switches, download a newer manual in the adult section. I.e. manual # 10
