Thanks for the response but forgive me as i was not exactly clear. There is a place for the switch to be installed on the motor....it just has a cover plate over the access point on the side where the switch is supposed to go. The motor was bought without the trim tilt switch installed on the actual motor but just on the throttle. But for convenience sake i want to also install this switch on the motor where it is supposed to go. The wiring is the issue...where do they plug in?
You can see the trim tilt switch on this motor...but on mine there is just a cover plate...no switch....i have to trim and tilt from the throttle handle.
I have the switch and wires just dont know exactly where they plug in/connect.
