Installing rule livewell pump
tab4593
Guys installing a new livewell pump rule model 401c. I am drilling a 1 inch hole per the directions and my question is this.
Should i use any water sealants or epoxy around the hole after I place the pump in the hole?
tab4593
Re: Installing rule livewell pump
Just an fyi, there is a gasket for the inside of the hull and a nut that screws on the outside of the boat. I will also be adding a rule strainer to the pipe.
